Will a 3000lb electric wench Pull my 3400lb car onto a trailer?? What lb rating is the avarage every one uses
Yes, it will! I used the elcheapo $49.00 1500# winch from harbor freight for a few years, Like MrPBody did.
I only had to tow the 3000# race car onto the trailor once. But I used it many times to tow other heavier vehicals onto the same trailor at heavier weights, 4500+ or so.
The old El Cheapo $49.00 1500# winch from Harbor freight worked pretty good.
My newer El Cheapo $89.00 3000# winch from Harbor freight is a train wreck. The cable as it unspools binds up like you wouldnt believe. That was never a problem with the 1500# winch.
You get what you pay for! Winch cable speed is also a serious consideration.
As far as wenches, They need love too!
Dont we all get along?? Wrench and Wenches!
