wow,never thought of the manifold switch.and what kind of motor mount set up did you use? did you weld boxes on the k-member where needed? and i will never put brand-x in any of my mopars!
I had square tubing welded to the frame with biscut mounts. I got the engine side brackets from Chassis Engineering. Are they still in business?
Marty
Marysville, OH
