I don't know the open pressure, they are PSI roller springs, the highest RPM was 6500. I followed the link about us cheap Mopar guys after I thought I could use this Chinese stuff. I got lucky and got away with no major damage. The hold downs were Hughes with studs torqued per Hughes recommendation. Nothing I received from PRW was any good, I haven't even got a refund for the damper that didn't fit. Hopefully the flexplate won't shatter on the next run.
70 Dart Swinger, 2850 lbs
SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
