Incredible build! Does the 518 bolt up to the 4BT without any mods or what did you need to make it work?
The back of the 4BT is the same as a 6BT ( Cummins ) so I used the adapter and trans from a 92 Dodge Cummins. Same starter also and the belt drive from the front of the Dodge.
Tom ,
2011 Ram 3500 C&C Diesel
2009 Challenger R/T
1971 Challenger Conv. 511/4 speed
1970 Challenger R/T 503/727
