Two ? 1)Can mild steel and chrome molly be welded together reason I'm asking i would like to keep he weight down as much as possible.I know the c/m needs to b tig just wondering if the two can be mated.2)Is there anything in the rule book that states mixing the two types of material....Thax.
Yes you can attach the mild to moly... BUT that joint
needs to be tigged because you are playing with
moly(at that point)
