68 Dart GTS H-code
combo as of now, might be time for some changes this winter....
505 CI HEMI machined and built by me
mega block, 4.400 bore 4.150 stroke eagle crank
diamond custom pistons, 10.7:1 1/16 1/16 3/16 moly rings
manly H-beams 6.865 Bob Weight 2627
Schneider Solid Roller custom ground 260/266 .620/.600 @ 112
BMS roller rockers 1.53 intake / 1.57 exhaust
Smith Brothers pushrods
MP Iron Heads, mild hand port and bowl work
MP cross ram, port matched. 2 Holley 770 cross ram carbs
Charlies 10 Quart oil pan w/ milodon single line external swinging pickup
MSD 6AL W/blaster coil
AC R44-XLS plugs (cheap and easily available)
Holley HP150 pump no return/ using stock gas tank
727 built by my Father
alum front drum
A&A valve body
9" J-Converter
Dana 60
Detroit locker
4.56 gears W Strange 35 spline axels
Caltrac's with mono leafs
Rancho adjustable shocks on rear
Calvert 90/10's up front with RMS tubular uppers and strut rods
Car weighs 3780 with a Half tank of gas and my ass in the seat
leaving from idle off foot brake
60'......1.446
330.....4.255
1/8.....6.605
MPH...104.54
1000...8.636
1/4.....10.359
MPH...130.38
