The PowerBond Unit also sold under Pioneer brand & PBM is the only damper I use other than ATI. It's my "budget" choice... have never had a single problem with one, even in 700-750 HP motors, including circle track use. I've probably used 35-40 of them.
I've had several Summit SFI dampers fail (slip).
http://www.summitracing.com/parts/PIO-872037/
When I did a search that one never came up. This is the one I ordered http://www.summitracing.com/parts/SUM-B64277/ is this the one that slipped or was it the cheap one? I don't want to screw up your work. It's been shipped but I can order a different one and send it back. What do you think.
70 Dart Swinger, 2850 lbs SB 408, Bullet roller 264/268 @50 .636 SSDS stage 2 Edelbrock heads, 1 7/8 Headmans, 1050 dominator by Dom, 9.867 @ 133
