Re: Gull Wing vs. Go Wing
[Re: DAYCLONA]
#102673
08/11/08 01:55 AM
08/11/08 01:55 AM
Posts: 5,275 near Harrisburg, Pa
440trk
near Harrisburg, Pa
Go-wings are the ones with sharply bent ends they were a 1970 release,.......although it is possible to see one of these on a early build 71
The gull-wing is the "soft" swept design,......as far as I know 71 was the last year offering these wings "factory" installed.....although it is possible for some cars from 72 and up, to be dealer equipped with either of these wings?
As far as the spacing, 36 inches is mopar, either wing,.....the 33 1/2 spacing, is a poor researched early repro Go-wing that was first offered, and some 71-73 Ford Mach 1 Mustang wings retrofited with Mopar pedestals,.....the Ford wings are 33 1/2 center to center on the legs also....
71-later should have the GULL wing, NOT the Go wing, unless it's a VERY early 71...in which case a 70 style GO wing was an oddball possibility.
DemonKyle, If your car is an EARLY 71, that may be the correct style of wing...although 99% of all 71's got the Gull wing.
