Too much positive pinion angle will cause a vibration on acceleration. Too much negative pinion angle will cause a vibration on braking or deceleration.
If your transmission slopes downward 3 degrees toward the rear and your pinion centerline is level, you have a -3 degree pinion angle. I don't usually like to see more than -3 for a street car.
I'm gonna find an expert and have them take care of this. It's confusing.
2010 Black Challenger SE <> 3.5 V6
Custom Shift Knobs www.flameball.com Check It Out
