I had some electrical problems with my 70RR including no dash lights, couple side marker lights out and turn signal/brake light not working. Now let me say I am very ignorant in the ways of electricity but I managed to fix everything except my brake light problem (so far everything was related to bad grounds). My tail lights both light up when the headlight switch is on and my drivers side brake light and turn signal both work but the passenger side brake light and turn signal do not work.
I have taken the bezels off and cleaned them as well as the light sockets them selves but no luck and I have run a jumper wire touching the passenger bezel to the drivers side bezel to double check the ground but no luck. I have read some of the other posts on this subject and do I now need to go into the turn signal switch?
If so I may have to get a friend over with more electrical knowledge but I wanted to see if there was any thing easy I am overlooking.
Paul
