do you already have the brake line T that bolts where the vent is?
i forget if some years this was separate from the soft line for the rear, or if it was part of it.
also what rear brakes are you running? stock small bolt pattern?
if you are going all stock * I think * you can order the flex line, T, and lines for any 67-72 a body
mike
