FYI any (if any) thin flat weights on the rear (curved) face of the TC are not to b touched. They are 2 bring the TC hunk of metal to neutral balance at the factory then one or 2 large weights (as said) are welded on the front flat face if it is then externally ballanced & those are the ones you work w
