yes, the engine size is also cast in large numbers on the driver side of the block. The numbers are about 1" tall if I remember correctly. Unfortunately, they are nearly behind the starter, so they can be real tough to see if you can't get under the car and the block is greasy.
Scott B.
"I'm a self-made man... I started with nothing, and I still have most of it!"
68 360 rusty B'cuda 'vert (GO Fish)13.59@ 98.72 mph
69 340 GTS stock 14.18@ 95.60 mph
01 5.9L Ram 1500 Quad Cab 4x4
01 3.5L 300M 16.23@ 86.97 mph
