9.25 and 5 psi isn't to much unless you are maybe running 38* timing. I run 33* at 5 psi 9.1:1 and 91 octane. How was the ring gap? Keithblack hyperutectic? Probably the problem with not enouph ring gap. No need to lower comp unless you want to run more boost.
11.67@118 1.88 60' with only 7-8 lbs of boost. Turbocharged, megasquirted, 407 BB, 440 source heads, roller cam, 9:1 comp. http://s292.photobucket.com/albums/mm14/beansgracie
