What's you're intended use? If mostly all street a disc with an organic facing will give good service life and smooth engagement. If street and strip a disc with organic on one side and ceramic or metallic on the other would be a good choice. McLeod or Centerforce would be good choices for either. Sachs makes good organic clutches, not sure if they have dual facings.
