I'm doing some final torquing of bolts and service manual says 50 ft/lbs for the 4 spd transmission to bellhousing bolts. It doesn't specify between aluminum or steel belhousing and I was wondering if the torq specs are the same for both. Don't want to strip the aluminum threads.
Any input is appreciated. Thanks....Joe
65 Barracuda
70 Challenger
