Quote: These are what the shop installed - I told them what cam I was planning on using, they said these Comp springs would be fine - charged me 90.00 parts/(mostly)labor,. Should I change 'em out ?
Let me guess, the shop you used normally does chebby engines, and they figured what works in a chebby will work in a Mopar. I went through the same thing. I was never happy with the way the engine revved. Even after taking the correct springs to the guy he used another spring. I ended up putting the correct springs on the engine and it really helped.
You are correct, sir. I'd rather not shell out another 100.00 on springs ...
