Here is the link to the old thread.
Paint job on a Budget
The only advantage I can see to the foam roller method is if your situation prevents you from spraying paint. Otherwise it is VERY labor intensive. Do you really want to roll on and wet sand several coats of paint, when you can spray some acrylic enamel and be DONE.
