Ohio crank and K-1 h-beam rods, was only spinning the motor at 7-7200 at WOT, but when it happened i had just installed the new tunnel ram and had made a nice burnout then staged and left the line at only 3400 on the Brake and got about 300 fett out when the car shook and i shut it down... checking in the pits, i found a lash cap off of #1 cylinder and tried to reset it and still had a dead spot, so havent done anything to the car in months waiting to have time off from work to pull the head and change the one valve i thought was bent.. this is what i found when i pulled it...
