Re: Stroker pistons, AKA "hockey pucks"
[Re: supercomp]
#1009814
06/10/11 01:56 PM
06/10/11 01:56 PM
Posts: 610 long time lurker, short time p...
PorkyPig
They will have less wall tension and less contact. With crank case pressure instead of vacuum it will make the rings job harder. Pressure makes it harder for rings to stay seated against bottom of ring groove. Yes we've used them with good success, but with a pump. JMO
Are you saying this about any 1.5 mm, 1.5 mm, 3.0 mm ring pack? I'm asking because Mahle sells a bunch of PowerPack replacement pistons with this same pack and these are intended to be pistons for street cars that I wouldn't expect to be using a vacuum pump.
Entire Thread
Cab_Burge
06/09/11 06:38 AM
Guitar Jones
06/09/11 10:28 AM
DragDart360
06/09/11 12:08 PM
JohnRR
06/09/11 02:42 PM
supercomp
06/09/11 03:00 PM
Cab_Burge
06/09/11 05:25 PM
supercomp
06/09/11 09:19 PM
LSP
06/10/11 04:08 AM
Cab_Burge
06/10/11 04:57 AM
supercomp
06/10/11 02:58 PM
PorkyPig
06/10/11 05:56 PM
moderncylinder
06/10/11 06:51 PM
440Jim
06/10/11 07:04 PM
jyrki
06/10/11 07:15 PM
Cab_Burge
06/10/11 09:19 PM
Performance Only
06/10/11 09:26 PM
Cab_Burge
06/10/11 09:31 PM
Quicktree
06/10/11 04:37 PM
Cab_Burge
06/10/11 04:42 PM
topfueldart
06/10/11 05:51 PM
RemCharger
06/10/11 06:12 PM
Quicktree
06/10/11 08:49 PM
