Ok, thanks a lot for the info.
Does anyone know if the replacement manual trans backup light switches come with gaskets (if they are needed during replacement?) ?
Also, do I need to drain my trans before removing the old one? Or is the level of this switch "above" the fluid level when the car is sitting flat?
Thanks !
