Here are the weights. Now I understand. Left is the total weight of the left side of the car 1527 lbs. Front weight is 1396 lbs. So if you add the front weights LF 857 lbs.+ RF 749 lbs.=1606 lbs. which is 53.5% on the front. Rear weight LR 670 lbs. + RR 726 lbs.=1396 lbs. which is 46.5 % on the rear.53.5%+46.5%=100%
