I set the timing on my 67 HEMI using the vacuum gage method (max vacuum - 1 inch) and ended up with 25 degrees initial and 40 degrees total. The total timing seems a little advanced to me. Thoughts???
Yes you set the initial properly but the total (initial+ slots & vac adv disconnected/plugged) cannot be finalized until you have the initial # in hand which means you need to shorten the slots and the tried & true totals that MP lists (35-sb 36-38-bb /6-32) are surprisingly dead on and you then play w the springs to adj the curve then plug in/adj the vac can. Not sure what it is for a Hemi as I never have owned one, have never worked one one and probably wont (in this lifetime) but I know it's not 40 ![](/ubbthreads/images/graemlins/Twocents.gif)
