Sounds like they got the toe front to back all out of wack. I had the same problem with my SRT-4 last time it was aligned. Did they give you a print out of the alignment? If so check the front and rear toe and make sure they are in spec. If the back is out it will cause a pull because the car is dog tracking. It will also cause the steering wheel to be off center. Ask me how I know.
