if you wire it normally, I think you'll need the adapter (when wired to the coil to sense the sparks) but most if not all MSD boxes have a special plug for a tach, if you wire it straight to that, it should work fine. that's how I did mine and didn't have any problems on a 6AL
**Photobucket sucks**
