Where to find AC fitting for new install #3232026
05/10/24 10:29 AM
05/10/24 10:29 AM
BDW Online content OP
BDW  Online Content OP
I need to find a male AC fitting to make the connection to a #10 female hose.
First pic is what I have now. The AC hose is directly welded to the end that I need to connect.
So that needs to be cut off, and a male receiver added, like dryer connection in 2nd pic.
Then I can connect new female hose, 3rd pic.
I can only find hose fittings, any ideas where to find a fitting like in 2nd pic that can be welded/brazed to the existing HW?
Re: Where to find AC fitting for new install [Re: BDW] #3232028
05/10/24 10:46 AM
05/10/24 10:46 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
That AC hose isn't welded on, it's crimped on.
Any good hose shop should be able to remove the old hose and crimp a new on on with whatever fitting you need on the other end. Assuming the original stuff is still good enough to reuse.
Re: Where to find AC fitting for new install [Re: Sniper] #3232029
05/10/24 10:57 AM
05/10/24 10:57 AM
Need a new fitting, so I can screw on a new hose.
That hose on there now is crimped, pretty sure, it's not a good idea to somehow remove and recrimp to a new hose.
So effectively that circled connection needs to be replaced.
Re: Where to find AC fitting for new install [Re: BDW] #3232033
05/10/24 11:18 AM
05/10/24 11:18 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
All those pictured fittings are designed specifically for A/C lines. Any commercial A/C repair shop will have them in stock. You can also look for a hydraulic systems repair shop, Heck, even Harbor Freight carries kits to hydraulically crimp that type of fitting.
Also, I see your receiver dryer is open to the air. How long has it been since that seal was broken? You may want to install a fresh one, as they become saturated with moisture from the air.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's
1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
Re: Where to find AC fitting for new install [Re: BDW] #3232045
05/10/24 12:12 PM
05/10/24 12:12 PM
John_Kunkel Offline
John_Kunkel  Offline
The circled part is called a ferrule, it's a sleeve that fits over the end of the hose and is then crimped. The ferrule can be cut off and the hose removed from the end of the metal tube. Problem is, the barbs on the end of the tube are incompatible with the new barrier hose so the old barbed end needs to be cut off and a new barbed end welded/soldered on.
As stated, any competent A/C shop can do this.
Re: Where to find AC fitting for new install [Re: John_Kunkel] #3232112
05/10/24 09:02 PM
05/10/24 09:02 PM
Went to 2 different AC shops today and both said no go.
Maybe they didn't want to be bothered. Partly the reason I was hoping to find a fitting and just have someone weld it.
I found fittings for.the hose on ebay, so I'll buy those and cobble it together. Won't be pretty, but I've given up on that, just need it to work.
Re: Where to find AC fitting for new install [Re: BDW] #3232136
05/11/24 08:32 AM
05/11/24 08:32 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I assume you are doing this to convert to 134 and a different compressor. Maybe get rid of the rusted R12 tube/hose/expansion valve and go direct out of the evaporator fitting on the fire wall.
Re: Where to find AC fitting for new install [Re: Moparite] #3232138
05/11/24 08:46 AM
05/11/24 08:46 AM
Az
69hemibeep Offline
69hemibeep  Offline
Az
A good A/C shop can make them, I watched the guy put the schrader valves into the fittings I needed.
1969 Hemi Roadrunner 2nd owner
Re: Where to find AC fitting for new install [Re: BDW] #3232156
05/11/24 10:30 AM
05/11/24 10:30 AM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Check here...
https://nostalgicac.com/fittings-hose-kits.html
FYI: R134 also requires a condenser designed for it, typically a multi-pass flow design.
