727 tranny #3228760
04/23/24 12:33 PM
04/23/24 12:33 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
my friend has a 727 non lock up tranny .it will not shift into 3 gear . could he have a lock up converter in it causing this problem?
Re: 727 tranny [Re: burks340] #3228765
04/23/24 12:54 PM
04/23/24 12:54 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
No , the lockup convertor is splined different so it wouldn't even go on the trans.
Is reverse working ?
Is his TV linkage adjusted correctly ?
Does it even have TV linkage ?
Re: 727 tranny [Re: JohnRR] #3228796
04/23/24 04:05 PM
04/23/24 04:05 PM
alabama, usa
burks340 Offline OP
burks340  Offline OP
alabama, usa
yes he has reverse .he sez that even if the kd linkage isnt adjusted correctly it should still shift into high gear sometime.he sez its a mopar converter and he has installed it in 2 different trannies and neither will shift into high gear .i will post part # on converter soon.
Re: 727 tranny [Re: burks340] #3228948
04/24/24 01:33 PM
04/24/24 01:33 PM
John_Kunkel Offline
John_Kunkel  Offline
The converter has nothing to do with shifting.
If it does the same thing with two different transmissions, suspect the TP linkage. Try temporarily disconnecting the linkage to see if it will then shift to 3rd.
