8 3/4 ID ??? help
#3228486
04/21/24 09:15 PM
04/21/24 09:15 PM
Posts: 6 Fairfax, Virginia
Juan-N-Million
Fairfax, Virginia
Hello all, can anyone help me identify what this 8 3/4 came out of or from what year it’s from ? I thought maybe it was a 489 casing and it was a defect b/c it doesn’t have a “9” at the end Thank you!!
Re: 8 3/4 ID ??? help
[Re: Juan-N-Million]
#3228497
04/21/24 09:53 PM
04/21/24 09:53 PM
Posts: 75,005 U.S.S.A.
JohnRR
U.S.S.A.
It's a 489 , the last digit of the casting number is MIA ... 489 had that large 9 cast on them.
does it have the caps , those are not a one size fits all , if it doesn't have them it's going to be $$$ to put another set on.
To me without them it's scrap, I just sold a few empty 489's , with caps , for 35 bucks a pop
#3228541
04/22/24 05:59 AM
04/22/24 05:59 AM
Posts: 5,812 ohio
ruderunner
ohio
Did the caps get marked before removing? They're side specific.
If not, bolt them oon and see if the adjustment threads line up. Switch sides and repeat.
Angry white pureblood male
[Re: fullonmopar]
#3228892
04/24/24 09:34 AM
04/24/24 09:34 AM
JohnRR
U.S.S.A.
I think the early ones up to 64 were 1820654 and small pinion Yes , the one pictured above is definitely a 489 , they are the only one with the large cast 9
[Re: JohnRR]
#3229037
04/24/24 11:30 PM
04/24/24 11:30 PM
Posts: 15,350 Omaha Ne
TJP
Omaha Ne
I think the early ones up to 64 were 1820654 and small pinion Yes , the one pictured above is definitely a 489 , they are the only one with the large cast 9 I'm confused, where do you see a "LARGE Cast 9" ?
[Re: TJP]
#3229047
04/25/24 01:29 AM
04/25/24 01:29 AM
Posts: 43,161 Bend,OR USA
I think the early ones up to 64 were 1820654 and small pinion Yes , the one pictured above is definitely a 489 , they are the only one with the large cast 9 I'm confused, where do you see a "LARGE Cast 9" ? How about the first picture next to the carrier adjuster cap area
