Re: rear springs 2935064
[Re: 1969ronnie]
#3228619
04/22/24 05:22 PM
04/22/24 05:22 PM
Posts: 3,075 Michigan
A727Tflite
Hi , If those have 8 Leafs per side , Somebody added some leafs because Factory 2835064 are 6 Leaf Springs and measure 35" front segment center Eye to center bolt , and Rear Segment is 20" from Rear Eye to Center Leaf Spring Center Bolt . Post what You have for Spring Measurements ? Did somebody add those A-Body Springs to another Spring Pack to make 8 Springs ? Front segment is 20”. All A Body and SS springs.
[Re: calrobb2000]
#3228693
04/23/24 02:24 AM
04/23/24 02:24 AM
Posts: 43,159 Bend,OR USA
What is the cast in (Stamped) number on the other spring? Depending on which motor was in the A body back then had a lot to do with which rear leaf springs they got, 6 cyl. and 318 cars got different ones than the 340 automatic cars got and the 340 4 speed car shad different ones(6 leafs on the passenger side on the 340 automatic cars and 7 leaf's on the driver sides on the 4 speed car, same thing on the 383 cars also.
