Crank hangs up after trans overhaul #3228090
04/19/24 01:33 PM
04/19/24 01:33 PM
MI, usa
dvw Online content OP
dvw  Online Content OP
MI, usa
First off let me state God was watching over me. Pulled the trans in my racecar for freshening. Started reinstalling the trans. Rotating the crank to install the 3rd converter bolt, crank stops, dead. Won't move either way more than 2-3 degrees. Don't want to force it backward with the Jessel belt. Pull the dist and oil drive, pump spins, losen the alternator (brand new) and vacuum pump belts, nope. Pull all the rockers and pushrods. All look great. Lifters can be pulled up with a piece of tig rod. Now the crank will rotate counter clockwise about 300 degrees and then, stops dead. Pull the trans back out to make sure something didn't hang up in the flexplate. I mean it was fine when the crank was rotated to pull the trans, right? Found nothing. Tried a bore camera saw nothing. Rreinstall the trans and pull the pan. Everything looks good. Pistons # 4 &# 7 won't clear TDC about 30 degrees either side. Take a guess at #4 1st. Pull the header. Pull the exh valve spring and replace with a checking spring. Try the camera and see nothing. I'm lost. Decide to pull the passenger head. Pull the intake. One last gasp. Pull the intake valve spring and swap with checking spring. Push the valve open. What do I see. A undamaged 5/16" nylock nut setting on the piston below the exhaust valve. Where did that come from? Only thing I can think of is when the accumulator was relocated during the alternator upgrade. It's the only item thats been removed that uses that nut. Engine had been started several times to check the alternator. Then moved into the hoist bay. Then started again after the oil change. I really hadn't cracked the throttle far until then. No marks on th episton. Cylinder leaks 5% cold. Not all a total loss of time. The screen windage tray was cracked again. So thats not going back. I'll fab a baffle above the pick up. The intake gaskets are climbing the head, again. So I'll replace them as well. First race is in 2 weeks.
Doug
Re: Crank hangs up after trans overhaul [Re: dvw] #3228094
04/19/24 01:38 PM
04/19/24 01:38 PM
K
Kiddart Offline
Kiddart  Offline
K
Geeez!!! Good luck and glad you found the problem!!
Thank you
Kiddart
Re: Crank hangs up after trans overhaul [Re: Kiddart] #3228098
04/19/24 01:47 PM
04/19/24 01:47 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Wow. What are the odds of that ?!
Glad you found it.
You've definitely earned the Perseverance Merit Badge on that deal.
Re: Crank hangs up after trans overhaul [Re: dvw] #3228104
04/19/24 02:26 PM
04/19/24 02:26 PM
WI
mopar873 Offline
mopar873  Offline
WI
I hope you went and bought a mitt-full of lottery tickets right away. Really dodged one there.....
Re: Crank hangs up after trans overhaul [Re: dvw] #3228105
04/19/24 02:30 PM
04/19/24 02:30 PM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
good catch, did the nut accidentally enter the carb or how else did it get there?
Re: Crank hangs up after trans overhaul [Re: DusterKid] #3228107
04/19/24 02:56 PM
04/19/24 02:56 PM
fast68plymouth Offline
Nice save!!
Re: Crank hangs up after trans overhaul [Re: fast68plymouth] #3228108
04/19/24 03:15 PM
04/19/24 03:15 PM
gregsdart Offline
gregsdart  Offline
Great catch Doug! On the gaskets, i had the same problem , but mechanical fuel injection allowed me to use silacone sealer, no gasket. Any minor air leak i could compensate for by adjusting the injection system . There must be a better way to seal that intake when running carbs. My guess is it will require some form of metal gasket with a sealant imprinted on it, or a MLS type gasket, pinbed to the head or intake?
Re: Crank hangs up after trans overhaul [Re: dvw] #3228142
04/19/24 07:03 PM
04/19/24 07:03 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
WOW that was a good catch for sure
....BAD A$$ STREET CAR.....
Re: Crank hangs up after trans overhaul [Re: dvw] #3228161
04/19/24 08:50 PM
04/19/24 08:50 PM
Doug
I'm not sure if God loves you or if he was giving you a test on this deal whistling work grin shruggy
Re: Crank hangs up after trans overhaul [Re: Cab_Burge] #3228197
04/20/24 12:29 AM
04/20/24 12:29 AM
Park Forest, IL
slantzilla Online content
slantzilla  Online Content
Park Forest, IL
Glad you found it.
Re: Crank hangs up after trans overhaul [Re: slantzilla] #3228211
04/20/24 06:51 AM
04/20/24 06:51 AM
Sticky South
Rodenteliminator Offline
Sticky South
Good find, starting it multiple times and moving it around and not doing any damage you would almost have to believe it worked its way in there on the last start. Doug
Sorry honey I spent the rent
Re: Crank hangs up after trans overhaul [Re: Rodenteliminator] #3228232
04/20/24 10:08 AM
04/20/24 10:08 AM
Plymouth, MI
Blusmbl Offline
Blusmbl  Offline
Plymouth, MI
That's a fantastic find and it's great you caught it before it hurt the cylinder head, a valve or a piston!
Re: Crank hangs up after trans overhaul [Re: Blusmbl] #3228254
04/20/24 11:49 AM
04/20/24 11:49 AM
Apollo, PA.
B1MAXX Offline
B1MAXX  Offline
Apollo, PA.
I had that once and it pinched the top ring slightly.
Re: Crank hangs up after trans overhaul [Re: B1MAXX] #3228461
04/21/24 07:15 PM
04/21/24 07:15 PM
gregsdart Offline
gregsdart  Offline
About 48 years ago a friend and i stopped to say hi to a guy working on his 1970 Chevelle 454 drag car. He was missing a carb stud nut, thought it rolled under the car . He fired the motor, heard BANG! BANG! BANG, TINKLE, as the missing nut came out rhe collecter! Pulled the head, three dings, no other damage. The big rollercam he had in it allowed that nut to enter and exit without damage to the valves or seats!
