Re: Need help identifying this 4-speed [Re: toast253] #3229158
04/25/24 04:27 PM
04/25/24 04:27 PM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
Originally Posted by toast253
Actually anyone have a good idea about how much to list this thing for? Not worried about getting maximum dollar, just want it out of my garage and in a good home.
Need to see what the inside of it looks like before being able to give you a true ball park, but getting the interlock side cover back on is a little tricky.
Re: Need help identifying this 4-speed [Re: toast253] #3229178
04/25/24 05:20 PM
04/25/24 05:20 PM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
Damn, that's a lot of knowledge. Thank you so much for all of the insight. I'll try to get all of the info wrapped up and get it posted for sale.
$500 if most 1/2 of internal parts are good: 1,000 if all are.
How does it feel while turning the input?
Any wobble of the input, indicates ok input bearing.
Re: Need help identifying this 4-speed [Re: Cuda340] #3229536
04/27/24 03:45 PM
04/27/24 03:45 PM
Clarksville, TN
toast253 Offline OP
toast253  Offline OP
Clarksville, TN
The numbers are pretty worn and I couldn't get a good picture but as best as I can tell it is stamped:
R01 on top
P8332404 0009 on the bottom of the machined pad.
Re: Need help identifying this 4-speed [Re: PhillyRag] #3229538
04/27/24 03:48 PM
04/27/24 03:48 PM
Clarksville, TN
toast253 Offline OP
toast253  Offline OP
Clarksville, TN
Ok cool , the input spins freely but it does feel a little wobbly. $500 it is, thank you for the input.
Re: Need help identifying this 4-speed [Re: toast253] #3229595
04/27/24 10:03 PM
04/27/24 10:03 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Most are to degree. Can't recall ever seeing one that didn't have a bit of play 🤔. hence the need for a pilot bearing and B/H alignment. 500 for a b body 18 spline? sounds a bit cheap to me but JMO. The real value depends on the condition inside wink twocents beer
Re: Need help identifying this 4-speed [Re: toast253] #3229597
04/27/24 10:12 PM
04/27/24 10:12 PM
PA
70HemiGTX Offline
70HemiGTX  Offline
PA
R01 on top
R01 Is that all that is on the top line?
