Re: 2002 Ram1500 replace radiator fan with electric fan?
[Re: tjmarcus1]
#3226576
04/11/24 09:10 PM
04/11/24 09:10 PM
Posts: 2,119 sc
tjmarcus1
sc
[b][/b] I had an electric fan on it, but when the weather got warm it wouldn't keep it cool. SO, I put the engine driven fan back on it. I LOST ABOUT 1 MPG. Plus the fact that the electric fan doesn't run continuously keeps the load off the alternator except when the fan comes on. I had it set up on a thermostat. the horsepower loss is noticeable too. Those factory fans and clutch is heavy!
[Re: stumpy]
#3226847
04/13/24 10:34 AM
04/13/24 10:34 AM
Posts: 984 rust belt
Moparite
rust belt
I had an electric fan on it, but when the weather got warm it wouldn't keep it cool. What fan and how was it installed? It needs to have a shroud that covers all of the rad cooling surface and have a lot of CFM. flex-a-lite makes some good fans with 6000cfm but they are not exactly cheap.
[Re: Moparite]
#3227064
04/14/24 04:54 PM
04/14/24 04:54 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
flexalite duel fan bolted right in to shroud on my V-10 ram went from 12 mpg to 11.99999999
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: volaredon]
#3227503
04/16/24 04:03 PM
04/16/24 04:03 PM
Posts: 10,562 Freeport IL USA
poorboy
Freeport IL USA
Due to space limitations, my 49 Dodge truck (on a 96 Dakota4 chassis) with a 5.2 efi has a very small radiator in it. The crossflow radiator core is 16" high, and 24" wide (the biggest off the shelf radiator that fits in the space available). It is a 4 core aluminum radiator Champion Radiator (V8 Chevy Monza listing). It has a single, high output, electric, 16" diameter, multiple curved blades, fan that is thermostatically controlled. Since the fan diameter covers the entire height of the crossflow radiator, there is no fan shroud other then the fan housing itself. The upper and the lower radiator hoses are on opposite sides of the crossflow core and the fan is positioned towards the upper radiator hose side of the radiator and effectively covers the entire height of the core (so it clears the mechanical belt driven water pump). The remaining radiator core is open for air to flow through it.
The last couple days we have been in the mid 80s around here. In town driving the electric fan cycles on and off regularly. On the highway there is enough air flow through the radiator the fan does not run while the truck is moving. When the fan kicks on, you can see it in the amp gauge jump (the fan is on a 30 amp relay), and you can hear it humming above the glass pack exhaust.
Electric fans have their place, but if you use one, make sure it produces adequate air flow to cool the motor. Electric fans that produce enough air flow draw current, and make noise.
[Re: tjmarcus1]
#3228244
04/20/24 10:48 AM
04/20/24 10:48 AM
Posts: 6,003 Salem
Grizzly
Moparts Proctologist
Salem
The usual Mo'Farts replies. I guess that's why all the MFG's have gone away from electric fans, huh? I'll start with reasons from my experience: 1. No roaring clutch fan. 2. Approx. 1/2 mpg better 3. No 8 pound dead weight hanging off the water pump. Have not had to do a water pump change since switching to electric. 4. Easier to work on with all the space freed up. 5. Vehicle is quieter, just more pleasant to drive in general. 6. No viscous to ever replace. I'm using an old Dodge Omni electric fan someone was throwing away on my 5600 pound '01 360. Wired to a 20 amp switch, it turns about as fast as a house fan on Low speed. Never a problem, barely use it. It takes 3 red lights in a row in traffic to require turning it on. The rest of the time, as long as you stay above 20mph the fan is never needed up to 85 degrees. Had my EC now for 15 years. I would recommend getting an OEM fan from a minivan or Dodge Neon and wiring to an aftermarket controller from Amazon. They are reliable and powerful. My personal experience would be to get rid of the shroud that blocks the rad off. I think half the problem with people having cooling issues is the rad is blocked off to funnel the air to the electric fan. If the block off is removed, air can pass freely through the rad. Another is the idea is the EC needs to be "on" at 180.........when vehicles have 195 thermostats, SMH, lol. If you are chasing mileage: between cutting my catalytic convertor out and electric fan, I picked up 1.5mpg out of my 360 Magnum.
Mo' Farts
Moderated by "tbagger".
[Re: Moparite]
#3229719
04/28/24 12:40 PM
04/28/24 12:40 PM
Posts: 6,003 Salem
Grizzly
Salem
You have 3 fans on the front of your vehicle?
If so, fans..........are not the cooling problem.
Mo' Farts
