RV 2 compressor parts #3226425
04/11/24 08:01 AM
04/11/24 08:01 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’m dealing with the sister company of Classic Auto Air out of Florida, Original Air. I’ve ordered the shaft seal and the hose seal kit. They are almost impossible to communicate with. They put you on hold for 1/2 hour before they even answer. Sometimes it just times out and hangs up. When I do finally get them, I still get a delaying excuse. Ive sources all the other parts I need, except the o ring that fits the front of the discharge side of a 70 b body. It’s not the gasket or the metal gasket but an o ring the fits in a groove on the hose side. Does anyone have a better source they have found? I have one or two that may work but I can’t test them until I get the shaft seal here. I’ve got a nitrogen bottle to pressurize the system. Any help is appreciated. I can’t find a part number in any book for this o ring or I would try that. Help.
Re: RV 2 compressor parts [Re: fastmark] #3226456
04/11/24 11:15 AM
04/11/24 11:15 AM
NJ
EV2RTSE Offline
EV2RTSE  Offline
NJ
I recently bought a reman RV2 compressor from this ebay seller, he also helped me out on the correct connector for a compressor clutch I had bought from someone else. I believe he owns or owned a rebuilding service and seems to have a lot of RV2 parts, seems like a good guy-
https://www.ebay.com/sch/i.html?ite...4429486.m3561.l170197&_ssn=billbt123
Also bought a compressor clutch key and the little wire retainer clip for the RV2 cylinder head from this seller, and he also seems to have a bunch of RV2 stuff-
https://www.ebay.com/sch/i.html?ite...29486.m3561.l170197&_ssn=13broberson
I messaged them both through ebay and they responded quickly with what I was looking for. Might be worth a shot.
Re: RV 2 compressor parts [Re: EV2RTSE] #3226480
04/11/24 12:51 PM
04/11/24 12:51 PM
SE Wisconsin, USA
RP's R/T's Offline
RP's R/T's  Offline
SE Wisconsin, USA
Original Air really went down-hill since COVID-world as respects Customer Service.
I sold my car with AC a few years ago and have an RV2 compressor and some extra clutches/pulleys left over if you are interested.
Re: RV 2 compressor parts [Re: RP's R/T's] #3226524
04/11/24 05:10 PM
04/11/24 05:10 PM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve got lots of old rv2 compressors. It’s the service gaskets, etc, that I need.
Re: RV 2 compressor parts [Re: fastmark] #3226533
04/11/24 05:54 PM
04/11/24 05:54 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
Last time I needed that O ring. I hit my local auto parts store ( not AutoZone either ) and had them match it up with a nitrile Oring.
Re: RV 2 compressor parts [Re: gtx6970] #3226635
04/12/24 05:34 AM
04/12/24 05:34 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I’ve done that but it does look a little small and I’m afraid it won’t seal. Once I get all my parts in, I can assemble everything, evacuate and test with nitrogen to be sure.
Re: RV 2 compressor parts [Re: fastmark] #3229343
04/26/24 04:27 PM
04/26/24 04:27 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
check with napa,most have a/c orings, asked them about the big blue box with 4-6 drawers
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: RV 2 compressor parts [Re: fastmark] #3229984
04/29/24 02:16 PM
04/29/24 02:16 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Try googling 2008388. That’s the discharge oring at the compressor.
Re: RV 2 compressor parts [Re: Leigh] #3230124
04/30/24 06:21 AM
04/30/24 06:21 AM
Abilene, Texas
fastmark Offline OP
fastmark  Offline OP
Abilene, Texas
I leave already done that. It’s in the parts book and it does not look quite right in the picture but I found some anyway on eBay and bought them. It’s actually the o ring the that goes on the EPR valve. I needed it anyway. I finally found the correct one in the kit from Old Air Products.
Re: RV 2 compressor parts [Re: fastmark] #3230413
05/01/24 08:53 AM
05/01/24 08:53 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
So, 2008388 is the epr seal? Glad you got it figured out.
