For Sale - Elephant Hemi Engines - 2nd Quarter
#3223971
03/31/24 12:10 PM
03/31/24 12:10 PM
Posts: 15,551 Norwich CT USA
moparts
Norwich CT USA
1964 Race Hemi A864
[Re: moparts]
#3224002
03/31/24 01:52 PM
03/31/24 01:52 PM
xx29
For sale: 1964 426 Race hemi. 1 of 2 experimental Hemi engines Chrysler sent to Isky for camshaft development. Pre-production block, stamped EXP-53. Standard bore, Kellogg crank std/std, fresh Hemi rods done by L&L rods in Pasadena, CA 40+ years ago, coated in cosmoline and in plastic bags, NOS Forged True pistons, 12.5:1 compression, with NOS Chrysler piston rings in boxes, NOS Isky camshaft, NOS lifters, K-heads with fresh valve job, new valves and springs, Cross Ram and Rat roaster intakes, Hooker Super Comp headers, motor mounts,Race Hemi dual point distributor, etc. This Race Hemi Engine is apart for inspection. Significant part of Chrysler 426 Hemi and American Hot Rodding history. $45000. Negotiable for serious buyers. Phone: 818-426-8685.
Hemi crankshaft
[Re: moparts]
#3224096
03/31/24 07:29 PM
03/31/24 07:29 PM
Posts: 631 Wisconsin
71duster414
Wisconsin
426 Hemi crankshaft. I got this with a recent parts purchase, haven't had it checked. Needs a polish.
$300
hoffmanhhr@gmail.com
Prestolite
[Re: moparts]
#3224368
04/01/24 08:19 PM
04/01/24 08:19 PM
71duster414
Wisconsin
66-67 hemi B body distributor for both manual and automatic transmission.
$750
NOS Magnesium Cross Ram, Stacks, 2 Sets Carbs,
[Re: moparts]
#3224517
04/02/24 01:50 PM
04/02/24 01:50 PM
Posts: 1,548 DC, MD Suburbs
440PURSUIT
DC, MD Suburbs
Selling my unused or NOS Magnesium Cross Ram with Plugs and Bell Crank. Herb McCandless saw at Indy and stated its for 1968. Unsure if its same as 65, but I won't doubt THE MAN.
Included is a set of 1968 Holley Carbs I bought new in 1998 with the repro Stacks with screens. These came through a Dodge Dealer. 2nd set of Carbs are race Carbs fro, the THT Dart. No Air Horns. I got these with a Elkings Modified Intake 20 years ago from the Former owner of that Car.
I also have an A and A kick Down Linkage and repro fuel Lines
$10,000 offer - Will post pics
I
Re: For Sale - Elephant Hemi Engines - 2nd Quarter
[Re: moparts]
#3225017
04/04/24 01:32 PM
04/04/24 01:32 PM
Posts: 1,362 Out of the State of Confusion
blue_stocker
New 130T steel/SFI 8 bolt McLeod flywheel, in the box...$300 plus shipping from Savannah, Tn. PM me here if interested. Thanks for the ad space Tom, much appreciate...wb
I predict future happiness for Americans if they can prevent the government from wasting the labors of the people under the pretense of taking care of them. Thomas Jefferson
Freedom must be repurchased by every new generation General Daniel Jones, WW2 Tuskegee Airmen
Re: 1968 Street Hemi Damper For Sale
[Re: xx29]
#3226492
04/11/24 02:08 PM
04/11/24 02:08 PM
Posts: 3 Patchogue
Ricky Racer
Patchogue
For Sale: Used 1968 Street Hemi Damper. Its in decent used condition. The rubber is in good shape, as are the keyway and bolt holes. It was degreed by a speed shop and I eventually replaced it with something else. I sold the hemi around 50 years ago so Its up for grabs. I just cleaned it up with some WD-40 so you can see what you are getting for your money. I didn't paint it bc you may have a different color choice. I've seen a used one advertised for something like $550, which sounds like a lot. So I'll put mine up for $250/ or best offer plus shipping from 11772. Thanks , Rick PS: It is SOLD!!! Thanks Moparts
[Re: moparts]
#3226584
04/11/24 10:30 PM
04/11/24 10:30 PM
Posts: 1,015 Howell, Michigan
Hemidavey
Howell, Michigan
426 Hemi Rocker stands. Purple Anodized Aluminum One full set are used. Good condition up top. Some dowl pin holes are a bit mushed, can be easily repaired. sold A Original set in good shape, drilled for 1/2 head bolts. Includes 20 new 3/8-16 rocker shaft bolts. 500.00 I have reducer washers if you run them with 7/16 bolts + 25.00 B Original set in good shape, no modifications. Includes 20 new 3/8-16 Rocker shaft bolts, 500.00 C Text me which ones you want to see and I'll send you photos.
Dave's Hot Rod Garage 734-231-070 five Thank you for the Ad
