6.4 rotating assembly into 5.7 builds #3221090
03/17/24 04:39 PM
03/17/24 04:39 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Wondering if anyone has built a combo out of a 5.7 block (early or late) with the crank and rods from a 6.4? I know the pistons wont work since they are over .170" larger, so wondering if there is an off the shelf piston for this that works? What heads and compression? Power numbers? Wondering what some have done since I know the 6.4 crank is supposed to be quite strong.
Any experience or combos you're willing to share are appreciated.
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3222100
03/22/24 12:02 PM
03/22/24 12:02 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
Ive contemplated the possibilities and decided it is just best to buy a good used 6.4 block and used pistons before boring a 5.7 block unless you had a brand new block that didn't need bored but you would still need custom pistons that cost as much as a good used 6.4 block. The 6.4 blocks have gotten a lot cheaper lately.
Re: 6.4 rotating assembly into 5.7 builds [Re: HotRodDave] #3222644
03/25/24 09:30 AM
03/25/24 09:30 AM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Thanks for the input Dave. Everything G3 hemi around here is still crazy expensive, guys still want 2k for early 5.7 cores although some pop up for $500-$800 from time to time. Anything 6.1 or 6.4 is crazy money still, but someone local was selling a 6.4 rotating assembly and I thought maybe the crank and rods could work with a custom or off the shelf piston. Just wasn't sure who was doing it. I figured the 6.4 pistons would be a no go just on the bore size alone.
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3222651
03/25/24 10:32 AM
03/25/24 10:32 AM
Pahrump NV.
Doright Offline
Doright  Offline
Pahrump NV.
I put 6.1 pistons in a 5.7 with Eagle heads and big cam makes great power @ 10.5 to 1 with a mild tune.
D Barnett
A&P mechanic,
FCC general radio Telephone operator.
Re: 6.4 rotating assembly into 5.7 builds [Re: Doright] #3223155
03/27/24 02:48 PM
03/27/24 02:48 PM
Toronto
mshred Offline OP
mshred  Offline OP
Toronto
Can you share any more details on it? Stock 6.1 pistons and 5.7 crank? What are the cam specs and power numbers?
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3227125
04/15/24 12:08 AM
04/15/24 12:08 AM
Nor here, Nor there
Dart 500 Offline
Dart 500  Offline
Nor here, Nor there
I would buy the rotating assembly and then keep your eyes out for a block and everything else needed, even if it requires a trip over the border. Piece it together over time
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3227877
04/18/24 12:00 PM
04/18/24 12:00 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
I just had a thought this morning, I'll try mocking it up today and let you know if it looks like it will work.
03 to 08 5.7 blocks are slightly taller and the later eagle pistons are slightly shorter, I am gonna try a 6.4 crank in an early 5.7 block with the later pistons and see how far out the deck they are and if not too much then maybe double up the head gaskets as long as the top ring don't go out of the chamfer in the cylinder and skirts don't collide with counterweights...
Re: 6.4 rotating assembly into 5.7 builds [Re: HotRodDave] #3227878
04/18/24 12:03 PM
04/18/24 12:03 PM
Kalispell Mt.
H
HotRodDave Offline
HotRodDave  Offline
H
Kalispell Mt.
should be a 359 or 5.9 litre plus a decent compresison bump but it won't allow for a big cam as there is no valve relief...
Re: 6.4 rotating assembly into 5.7 builds [Re: HotRodDave] #3228886
04/24/24 08:50 AM
04/24/24 08:50 AM
The Great White North
RAMM Offline
RAMM  Offline
I did this with Icon pistons and a 6.125" rod length. The pin bosses did interfere with the counterweights. J.Rob
2009 PHR\EMC Competitor
2010 PHR\EMC Competitor
2011 PHR\EMC Competitor
2012 PHR\EMC Competitor
2013 PHR\EMC Competitor
2014 HotRod/EMC Competitor
2015 HotRod/EMC NoShow
2016 HotRod/EMC 3rd place SPEC Bigblock
2018 HotRod/EMC 7th place G3
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3228887
04/24/24 08:53 AM
04/24/24 08:53 AM
RAMM Offline
RAMM  Offline
I have a 6.4 longblock for sale Mshred. The heads are ported Eagles and they were ported by member SixPackGut. J.Rob
Re: 6.4 rotating assembly into 5.7 builds [Re: mshred] #3228888
04/24/24 08:59 AM
04/24/24 08:59 AM
RAMM Offline
RAMM  Offline
