Need to mod steering line #3196160
12/08/23 08:27 PM
12/08/23 08:27 PM
BDW Online content OP
BDW  Online Content OP
I need to mod my power steering line / hose to clear up room to connect the AC line to the compressor.
The SS line runs straight down and blocks the compressor port.
Would it be possible to bend the line up a little, thinking it might collapse it?
Or just get a 45 or 90 AN adapter?
Any other ideas?
Re: Need to mod steering line [Re: BDW] #3196164
12/08/23 08:50 PM
12/08/23 08:50 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
looks to me like you could move the metal line outward a little and find room. You shouldn't have bend it enough to kink it.
Re: Need to mod steering line [Re: BDW] #3196171
12/08/23 09:32 PM
12/08/23 09:32 PM
MarkZ Online boogie
Worthy
MarkZ  Online Boogie
Worthy
Could make up your own from scratch with PTFE line.
Re: Need to mod steering line [Re: MarkZ] #3196175
12/08/23 09:43 PM
12/08/23 09:43 PM
The steering hose is laying on the port, that's a plastic protector cap.
I need to add adapter fittings on the compressor, so the steering hose needs to move away quite a bit.
Here's a reference pic with the adapters on a compressor.
Re: Need to mod steering line [Re: BDW] #3196183
12/08/23 11:08 PM
12/08/23 11:08 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Not sure what size the line is but a tube bender similar to this will make that a simple task they're available in a number of sizes. I prefer the dedicated size ones vs the one size does all wink
LINKY
Re: Need to mod steering line [Re: BDW] #3196500
12/10/23 02:53 PM
12/10/23 02:53 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Any other ideas?
Don't know what the top connection of the steel line looks like, but it appears to me that the entire length could be rotated outward, away from the inner fender, and routed on the other side of the plastic tab at the top, and the hose at the bottom and have more clearance all around.
Re: Need to mod steering line [Re: poorboy] #3227587
04/16/24 09:57 PM
04/16/24 09:57 PM
Follow up, used a 45 JIC fitting, and it provides the clearance needed.
Been driving with no leaks, need to get motivated and build the AC lines, summer is almost here……
