Brand X engine question
#3073171
09/01/22 09:13 AM
09/01/22 09:13 AM
Posts: 670 Third rock from the sun.
busboy
Morning All, my buddy (Buick guy) is getting rapid increasing crank end play on his 455. Build spec is .003-.009, his was .006 but after not many miles, less than 500, it’s up to .015. His forums not being much help, hoping some of you engine aces can chime in with a possible cause/solution. Not aware of any such issue with our Mopars. It’s a 70’ GS 4 speed car.
Oh yeah, it's a hybrid.....it burns gas and tires!
Re: Brand X engine question
[Re: busboy]
#3073205
09/01/22 10:42 AM
09/01/22 10:42 AM
Posts: 75,020 U.S.S.A.
JohnRR
U.S.S.A.
Morning All, my buddy (Buick guy) is getting rapid increasing crank end play on his 455. Build spec is .003-.009, his was .006 but after not many miles, less than 500, it’s up to .015. His forums not being much help, hoping some of you engine aces can chime in with a possible cause/solution. Not aware of any such issue with our Mopars. It’s a 70’ GS 4 speed car. 4 speed car , everytime he pushes in the clutch it forces the crank into the thrust bearing, either the crank surface is going away or the bearing is going away. If he didn't set the thrust bearing correctly when first torquing that main cap this could be a possible reason the clearance has grown , which would say he has an issue that he didn't see during assembly.
[Re: JohnRR]
#3073219
09/01/22 11:04 AM
09/01/22 11:04 AM
Posts: 43,198 Bend,OR USA
[Re: Cab_Burge]
#3073229
09/01/22 11:25 AM
09/01/22 11:25 AM
Posts: 20,179 Park Forest, IL
slantzilla
Park Forest, IL
Another question is how many RPM is he turning it? Much over 5500 and Buicks will eat the mains. A stock 455 block is about as strong as wet spaghetti.
[Re: JohnRR]
#3073278
09/01/22 01:37 PM
09/01/22 01:37 PM
Posts: 11,583 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Morning All, my buddy (Buick guy) is getting rapid increasing crank end play on his 455. Build spec is .003-.009, his was .006 but after not many miles, less than 500, it’s up to .015. His forums not being much help, hoping some of you engine aces can chime in with a possible cause/solution. Not aware of any such issue with our Mopars. It’s a 70’ GS 4 speed car. 4 speed car , everytime he pushes in the clutch it forces the crank into the thrust bearing, either the crank surface is going away or the bearing is going away. If he didn't set the thrust bearing correctly when first torquing that main cap this could be a possible reason the clearance has grown , which would say he has an issue that he didn't see during assembly. All of this is correct. Crank install process needs to be correct...but 10 thou in 500 miles is a big bunch. I would be looking at something pushing the crank forward in the block. Input shaft bottomed in the back of the crank or the pilot. Guy ride around with his foot on the clutch pedal. Something. I would drop the pan, pull the bearing and verify where the wear is. Front, rear, both. and go from there. Get the trans out and look.
[Re: CMcAllister]
#3073308
09/01/22 03:07 PM
09/01/22 03:07 PM
busboy
Thanks for the replys. Experienced driver, no foot on clutch, not beating on it, street car no racing, input shaft was checked, Will confirm crank install procedure, he has a number of engine builds under his belt. Another local Buick guy mentioned teflon bearings may help but I think that may just be a coating, doesn’t sound like a permanent solution.
