Re: Rich Edelebrocks
[Re: AndyF]
#2625694
02/25/19 12:20 AM
02/25/19 12:20 AM
Posts: 211 Halifax, VA.
moparjack44
Halifax, VA.
Have you hooked up a vacuum gauge and adjusted the idle mixture screws for highest vacuum at idle? No, sound and RPMs only. Gonna borrow a vacum gauge tomorrow and check that. I'm going to check the floats?
K.I.S.S.
[Re: moparjack44]
#2626393
02/26/19 05:13 PM
02/26/19 05:13 PM
Posts: 4,563 Motor City
6PKRTSE
Motor City
I used to run dual 750 cfm (Eddy 1407's, I think was the number) on my Hemi. Yes, they were rich to start but after playing with the metering rods and jetting 4 or 5 times It ran flawlessly, started right up, idled fine and was not too rich on the street. Hemi's like cfm.
[Re: 6PKRTSE]
#2626686
02/27/19 12:16 PM
02/27/19 12:16 PM
moparjack44
Halifax, VA.
I used to run dual 750 cfm (Eddy 1407's, I think was the number) on my Hemi. Yes, they were rich to start but after playing with the metering rods and jetting 4 or 5 times It ran flawlessly, started right up, idled fine and was not too rich on the street. Hemi's like cfm. Thanks. I have ordered the Edelbrock calubrating kit, is suppose to be here today. I'm going to start by changing the metering rods to same as the Edelbrocks set up on the carbs they sell "specifically" for a 2 4 set up. I will keep every one advised how it wotks. If that doesn't work, I wii go to the jets.
K.I.S.S.
[Re: moparjack44]
#2626725
02/27/19 02:05 PM
02/27/19 02:05 PM
Posts: 1,696 central il.
second 70
central il.
Don't forget you need 2 calibration kits 1 for each carb.
[Re: dvw]
#2626826
02/27/19 07:09 PM
02/27/19 07:09 PM
moparjack44
Halifax, VA.
After reading through this thread a few questions. Without any O2 how are you determining that the carbs are rich? Soot on the plug? Do you have the correct heat range plug?If so how do you know if it's at idle or wot. Could be caused by weak spark as well. How does the car perform for power? How about idle quality? Are the seats tight in the carb lids? Have you pulled the lids to verify float level? Have you cleaned the idle air bleeds? Doug Yes, scote on the plugs. Yes, correct heat range on the plugs, I believe? I'm pretty sure idle and cruise speed, very rarely ever at WOT. Spark, I don't know. New MSD ready run, electronic distributor, new NKG plugs, new MSD wires. New MSD Blaster 2 coil scheduled to be delivered today by UPS. Idle quality, OK, except smell and burns the eyes. Exhaust tips, black as coal. Seats tight, I have not checked. Have not checked floats, but on my "To Do List". Idle air bleeds, details/help please? Jack
K.I.S.S.
[Re: moparjack44]
#2626832
02/27/19 07:22 PM
02/27/19 07:22 PM
Posts: 43,124 Bend,OR USA
I would start with adjusting the idle mixture screws on all four of them to try and clean up the idle fuel mixture Start the car up a drive it, if you can, for 15 to 20 minutes to warm it up and then start by adjusting one of the rear carb idle mixture screws in very slowly until you hear a change in the idle RPM., get it to idle as fast as it will Once your done with it one do the other side and then adjust the fronts. After doing all four go back to the rear and see if you can make it change again for the better or worse, once you got it the way you like it go drive it around again at light part throttle to see if it will clean the plugs up some and the drive it a little harder also Let us know your results
[Re: Cab_Burge]
#2626968
02/28/19 01:43 AM
02/28/19 01:43 AM
moparjack44
Halifax, VA.
I would start with adjusting the idle mixture screws on all four of them to try and clean up the idle fuel mixture Start the car up a drive it, if you can, for 15 to 20 minutes to warm it up and then start by adjusting one of the rear carb idle mixture screws in very slowly until you ear a change in the idle RPM., get it to idle as fast as it will Once your done with it one do the other side and then adjust the fronts. After doing all four go back to the rear and see if you can make it change again for the better or worse, once you got it the way you like it go drive it around again at light part throttle to see if it will clean the plugs up some and the drive it a little harder also Let us know your results Sounds like a plan. Hope to get started on all I need to do, 1st thing tomorrow. UPS did not bring all my parts today.
K.I.S.S.
[Re: Supercuda]
#2627434
03/01/19 11:24 AM
03/01/19 11:24 AM
moparjack44
Halifax, VA.
I called Edelbrock Tech yesterday to see if my brilliant idea of changing the jets, spring, and metering rods would work to make my 1401 & 1402 be compatible to the 1801 & 1802? He advised would probably help, but the 1801 & 1802 had been discontined. They have been replaced with 1901 & 1902, and they were completely different, even from the 1801 & 1802?
K.I.S.S.
