Page 3 of 3 1 2 3
Re: Pro Street '68 Dart in Hot Rod [Re: AndyF] #2640808
04/03/19 06:28 PM
04/03/19 06:28 PM
Canada
cuda499 Offline
cuda499  Offline
Canada
Originally Posted by AndyF
Some really nice looking work on this car. I'd like to see it in person. Looks like the guy did a ton of stuff on this car.
https://www.hotrod.com/articles/1968-dodge-dart-first-love/
Really nice car and my FAV year too! only things I would change.... it would sit about 4 inches lower, and it would have a gen3 hemi in it.
Re: Pro Street '68 Dart in Hot Rod [Re: cuda499] #2645877
04/16/19 10:54 PM
04/16/19 10:54 PM
CA, USA
JcodeCharger Offline
CA, USA
Thanks, although it won't go any lower unless you put a tube chassis under it. The front is a 1/2" off the bump stops. Gen3 Hemi? No way.
68 twin turbo Dart 8.19 so far
70 Swinger 360
69 Roadrunner 383 4 speed
69 Mod Top Satellite 383 auto
69.5 A12 Super Bee 4 speed
70 T/A Challenger
70 FC7 Duster 340 4 speed
70 FJ5 Superbird
68 Hemi 4 speed Roadrunner
71 Duster W2 340
Re: Pro Street '68 Dart in Hot Rod [Re: JcodeCharger] #2645878
04/16/19 10:57 PM
04/16/19 10:57 PM
CA, USA
CA, USA
Went back to Irwindale and this time the converter is TIGHT! So here are some low boost passes. Time to start adding in timing, leaning out the AFR a little, and shifting higher.
https://youtu.be/jkImQugkxGM
https://youtu.be/HfOHDGZ351w
https://youtu.be/zrDFHCcoanQ
https://youtu.be/7vGTN6O75AI
70 Swinger 360
70 T/A Challenger
70 FJ5 Superbird
71 Duster W2 340
Re: Pro Street '68 Dart in Hot Rod [Re: JcodeCharger] #2645899
04/17/19 12:34 AM
04/17/19 12:34 AM
How much boost and what are the 60 ft. times now?
Re: Pro Street '68 Dart in Hot Rod [Re: Cab_Burge] #2645903
04/17/19 01:10 AM
04/17/19 01:10 AM
CA, USA
CA, USA
I left on 6.9 pounds and the high was 10.6 with most of the run around 9 psi. The 60' was a 1.30.
70 Swinger 360
70 T/A Challenger
70 FJ5 Superbird
71 Duster W2 340
Re: Pro Street '68 Dart in Hot Rod [Re: JcodeCharger] #2646059
04/17/19 01:23 PM
04/17/19 01:23 PM
My guess miss on your 60 ft. times a bunch blush those times are good with a lot of room for future improvements up
Re: Pro Street '68 Dart in Hot Rod [Re: Cab_Burge] #2647588
04/21/19 04:54 PM
04/21/19 04:54 PM
CA, USA
CA, USA
I think there is. I am short shifting it at 6500, the timing is at 24 degrees, and the target AFR is 11.5 to 1. Next week I am going back to the dyno to lean out the tune up and find the optimal timing as well as see if it'll continue to make power up to 7500 rpm. I still also can leave on much higher boost. The suspension isn't tuned all the way but its pretty close. So there is still a lot of R&D to do. This is so much fun. I am also planning on taking my freshly dyno'd set up to Irwindale the following Thursday May 2.
70 Swinger 360
70 T/A Challenger
70 FJ5 Superbird
71 Duster W2 340
Page 3 of 3 1 2 3
