Re: Life expectancy of my red line tires
[Re: Kern Dog]
#2610457
01/22/19 03:26 PM
01/22/19 03:26 PM
Posts: 2,820 Connecticut
FurryStump
Connecticut
Shoot...I wouldn't do 100 mph with a NEW set of those tires! how about 125+?;)
[Re: 420SIX]
#2611430
01/24/19 03:47 AM
01/24/19 03:47 AM
Posts: 1,655 Cut and Shoot, TX
kentj340
Cut and Shoot, TX
No need to wonder. There's a test for this.
On a relatively new tire, depress the tread with your thumb and note how pliable and soft it is. This is how a tire should feel.
Repeat this test on old tires in question. If there's a big difference, if hardness and brittleness are detected, the tires are too old. It's time to replace them with new tires no matter how much tread is left and even if there is no visible cracking.
I have a Wide Oval tire that's almost 50 years old, and it's not cracked, probably because it was a spare kept out of sunlight. It's rubber is so hard I could not dismount it myself using a 12-ton press. Had to take it to a tire store.
