Re: A body factory rear alignment way off
[Re: humpty]
#2607512
01/16/19 03:03 PM
01/16/19 03:03 PM
Posts: 8,021 Tulsa OK
Bad340fish
Tulsa OK
I would say yes, mine was similar. I centered mine off of the frame rails which may or may not be correct.
68 Barracuda Formula S 340
[Re: humpty]
#2607513
01/16/19 03:03 PM
01/16/19 03:03 PM
Posts: 4,669 Wichita
GY3
Wichita
I had a '75 Duster that was like that.
[Re: humpty]
#2607618
01/16/19 05:08 PM
01/16/19 05:08 PM
Posts: 11,530 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
QC in the day was "yep, it rolls".. I've come to accept that you often have to make something crooked to make it look straight.
I would establish a centerline off of the rocker pinchwelds. And I would drop stringlines to check spring mounts front and rear, frame rails, etc. If one of the front perch mounts was closer to the center, you could put the spring perches on the housing offset, but I would probably fix or modify one or both of the mounts to get it right. 1/8" is not bad. 3/8" is a bunch.
[Re: humpty]
#2607632
01/16/19 05:50 PM
01/16/19 05:50 PM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Yep. Invest in a plumb bob.
[Re: humpty]
#2607643
01/16/19 06:11 PM
01/16/19 06:11 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Good. I'd rather see stuff fixed than half a$$ed. Put a few of these in the air and start dropping stringlines and you get to a point where if you find one that's reasonably straight, you're pleasantly surprised. Not just Mopars, but all of them from the muscle car era.
