340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? #2606716
01/15/19 12:30 AM
01/15/19 12:30 AM
Macomb, MI
V
vinnyd76 Offline OP
vinnyd76  Offline OP
V
Macomb, MI
If I recall correctly, there was an idle solenoid (and bracket) present on a 70 440 4-Barrel Carter Carburetor, but is there one present on a 70 340 4-Barrel Carter? I see they reproduce the idle solenoid bracket for 340 Six-Pack, but not 4-barrel applications.
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: vinnyd76] #2606746
01/15/19 01:27 AM
01/15/19 01:27 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
Yes, should have the same bracket, solenoid number DR1114442
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: vinnyd76] #2607183
01/15/19 09:35 PM
01/15/19 09:35 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
edit double post
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: gtx6970] #2607185
01/15/19 09:37 PM
01/15/19 09:37 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
To clarify, Same bracket between 340 4 bbl and 340 sixpack.?
Is NOT the same
between the 2 four barrel applications mentioned it is ( and not easy to find I might add))
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: vinnyd76] #2607332
01/16/19 03:04 AM
01/16/19 03:04 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Nope, I was talking about the bracket that fits 340 & 440 AVS carbs are the same, solenoids look the same too, just a different number stamped into them. 1970 340 Six pack, 440 six pack, and 426 Hemi, all use the same DR1114429 Solenoid with integral bracket. 1971 426 Hemi and 340 4 Barrel TQ also use this same DR1114429 solenoid.
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: ScottSmith_Harms] #2607406
01/16/19 11:38 AM
01/16/19 11:38 AM
MD
floyd Offline
floyd  Offline
MD
Here's one Scott restored for me awhile back.
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: vinnyd76] #2607553
01/16/19 03:46 PM
01/16/19 03:46 PM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
While discussing the idle solenoids with integral bracket there is also the Mopar one application only DR1114443 71 440-6 solenoid.
Re: 340 4-Barrel Carter Carbs - Idle Solenoid and Bracket? [Re: vinnyd76] #2607860
01/17/19 12:55 AM
01/17/19 12:55 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
Yea, that DR1114443 unit is a rare one....Those were also on early 72 340's.
