Tallest and widest tire for this combination: #2589329
12/09/18 01:42 PM
12/09/18 01:42 PM
USA
H
hudsonhornet7x Offline OP
H
USA
1968 Charger
Us CarTool mini tub and spring relocation kit
15x8.5" wheel with 4.990" backspacing.
Stock Dana 60.
I am just learning about the drag racing side of life, and I would like to know what the widest and tallest drag radial would be to fit.
If I have not provided enough information please let me know, and thank you Moparts members for some advice.
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2589361
12/09/18 02:37 PM
12/09/18 02:37 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
I know a 325 drag radial fits no problem...We ran them on a 70 Charger.
'70 Cuda,...605 EFI Hemi Street Car (6.20 best pass, 1.33 60ft)
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2589394
12/09/18 03:22 PM
12/09/18 03:22 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
295 should fit no problem, and they are 29.5 so it won't look small like a 275. How fast you looking to go ?
....BAD A$$ STREET CAR.....
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2589425
12/09/18 04:16 PM
12/09/18 04:16 PM
Cab_Burge Online work
Cab_Burge  Online Work
315x60x15,295x65x15,325x50x15 scope
A 10 inch wide wheel will work better also work shruggy
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2589448
12/09/18 04:38 PM
12/09/18 04:38 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
That wheel will kinda limit you. I'm no drag radial expert but a 295-65-15 will fit without mini tubs, I don't know if I'd go any bigger on that wheel
Past research indicates 15x12 with 7.5" backspace, 30-ish max height and 16 to 16.5 max section width is about the limit.
Something slightly less than that should be a near perfect fit on a rim of that spec. Right around this dimension https://www.jegs.com/i/Hoosier/522/18195D06/10002/-1
Usually I don't post unless I've done something but ....ask anyone who has gone to events with me, they will tell you I've looked underneath alot of cars to see what was done (weirds people out) and took alot of notes over time. I'll probably head down that road eventually when I cut the quarters off the old b body.
Rich H.
Esse Quam Videri
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2589480
12/09/18 05:48 PM
12/09/18 05:48 PM
USA
H
H
USA
Thank you all for the replies. I have a specific wheel I want to use and it is 8.5" wide. Maybe I should have the rears widened.
Re: Tallest and widest tire for this combination: [Re: hudsonhornet7x] #2590787
12/12/18 12:13 PM
12/12/18 12:13 PM
an8sec70cuda Offline
295-65 radial fits the 8.5" wheel perfect. It's what I run on my cuda.
CHIP
'06 GMC 2500HD LBZ Duramax
