Re: Magnetic drain plug for A833?
[Re: 4406bbl]
#2571962
10/31/18 04:04 AM
10/31/18 04:04 AM
Posts: 43,193 Bend,OR USA
Hemi 4-speeds had them from the factory. None of them that I used did I raced them from pre mid year 1969 model years though I worked for the local telephone company back then and I would remove the magnets from the bad ringers, usually the coils would go open, and epoxy them into the drain plugs I've seen some of the later aluminum case O.D. 4 speed tranny with a magnet fastened, glued, inside the cases on the bottom also OP, if your dealing with a stock cast steel case slide it in near the drain plug and use it that way
[Re: 4406bbl]
#2572006
10/31/18 09:52 AM
10/31/18 09:52 AM
Posts: 4,283 Florida
blewbyu
Hemi 4-speeds had them from the factory. The A12 Hemi one I just rebuilt had one it it also.
[Re: gss]
#2572221
10/31/18 04:04 PM
10/31/18 04:04 PM
Posts: 25,817 Rio Linda, CA
John_Kunkel
1/2"-14 NPT magnetic drain plug, available from just about everywhere.
[Re: John_Kunkel]
#2572248
10/31/18 04:49 PM
10/31/18 04:49 PM
Would it be beneficial to buy or make one like Pac said that had more magnet protrusion?
[Re: gss]
#2572318
10/31/18 07:04 PM
10/31/18 07:04 PM
Posts: 13,595 md
mopars4ever
md
[Re: Andrewh]
#2572490
11/01/18 02:14 AM
11/01/18 02:14 AM
surface area is bound to get more items, but most rare earth magnets are also very brittle. so you have to take that into account. plus it would be based on flow past it as to how effective it might be. Noted
[Re: John_Kunkel]
#2576198
11/09/18 02:52 AM
11/09/18 02:52 AM
Posts: 1,121 State, country, etc.
gss
1/2"-14 NPT magnetic drain plug, available from just about everywhere. That's the fill plug. Drain is smaller. I would guess 3/8" NPT.
