Re: Borgeson steering box
[Re: 71TA]
#2649557
04/27/19 02:59 PM
04/27/19 02:59 PM
Posts: 2,578 sweden
1Fast340
sweden
Turns out I need to use the Type II box since the Saginaw pump will not fit with the motor mount that I'm using. The outlet port runs right into the motor mount and there is no easy fix that I can see. What are those there shorty headers? I would guess its a set of these: https://www.engine-swaps.com/Pages/ProductsType/BRB_Headers.html
[Re: AndyF]
#2652076
05/05/19 05:42 AM
05/05/19 05:42 AM
Posts: 3,575 The Netherlands
BigBlockMopar
The Netherlands
My Borgseon box was angled deadstraight when installed at first (small sectorshaft but '73 K-member/Dart). But after I installed Doug's headers a few years later I had move the engine and P/S around a bit to have the (stock) steeringcoupler clear the nr. 7 exhausttube. It's at a very slight angle now.
[Re: Sxrxrnr]
#2653080
05/07/19 05:33 PM
05/07/19 05:33 PM
Posts: 602 Portage Wisconsin
Lou_Steger
Portage Wisconsin
Installed in our Ebody, 5 plus years ago. Like now, but one hell of an adventure to get it dialed. Do a search on Borgeson and read some of the older threads. Also put one in wife’s 55 T Bird. Another adventure as they had never offered a system for the Bird. Adapted a full size Ford unit to the Bird. Works well Could you elaborate on what you mean by "adventure"?
[Re: Lou_Steger]
#2653132
05/07/19 07:48 PM
05/07/19 07:48 PM
Posts: 1,272 Northern Calyfornua
Sxrxrnr
Northern Calyfornua
Installation was a real pita. After many weeks finally came up with shimming of box in order to get proper toe alignment. Borgeson tech support was let me put it politely,,,,less than adequate. It was always user error until I discovered their real problem which was in machining and jigs to attach mounting ears. Subsequently others found exact same issues. Once shim was created an installed, all was ok. I did a search for my old threads. For some reason only found going back to 2016. Those from 2014 til then are not listed. This is where main adventure and photos were. This url will show some of my thread,,,,but only those 2016 or later. They are listed by my handle. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/dosearch/topic/0/Searchpage/8.html
[Re: Sxrxrnr]
#2653593
05/09/19 08:07 AM
05/09/19 08:07 AM
Lou_Steger
Portage Wisconsin
Installation was a real pita. After many weeks finally came up with shimming of box in order to get proper toe alignment. Borgeson tech support was let me put it politely,,,,less than adequate. It was always user error until I discovered their real problem which was in machining and jigs to attach mounting ears. Subsequently others found exact same issues. Once shim was created an installed, all was ok. I did a search for my old threads. For some reason only found going back to 2016. Those from 2014 til then are not listed. This is where main adventure and photos were. This url will show some of my thread,,,,but only those 2016 or later. They are listed by my handle. https://board.moparts.org/ubbthreads/ubbthreads.php/ubb/dosearch/topic/0/Searchpage/8.html For some reason I can't get the link you provided to work. Anyway is the box you are using the welded or cast one?
