Re: Keith Black, Inc. - New HEMI and WEDGE engine blocks
[Re: TRENDZ]
#2586647
12/03/18 03:35 PM
12/03/18 03:35 PM
Posts: 1,397 Carson City, Nevada
Biginchmopar
Carson City, Nevada
I realize this is not a finished block, but with as accurate as described machining, shouldnt the exhaust pushrod clearance holes intersect the bore/ deck in the same location on every cylinder? I think what you are seeing is it is very thin right there and I believe the one might have a little piece broke off. Not really a big deal because like said before a lot more material will be removed in that area before all is said and done.
[Re: dthemi]
#2588691
12/07/18 05:46 PM
12/07/18 05:46 PM
Posts: 125 Loganville, GA
Stewart
Loganville, GA
DT WB not with us but Frank made me feel stupid enough when I asked him about it. " How can you have messed with Hemis since 1970 and not notice this?" "Haven't we taught you anything?" I would have walked away but we were half way between Atl and Indy and Frank was driving. Frank had fun with this. Back home now and about to go to the shop and I am going to take a CLOSE look at the heads and see what I have missed all these years. Maybe I knew this once and just forgot.
[Re: Keith Black®]
#2589224
12/09/18 01:06 AM
12/09/18 01:06 AM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
I used to marvel at buddy's porting work on cast iron. He made the ports look like a cnc polisher did them.
Porting off the guide centers is a better way to go. Making them all the same.
I'm 4.78 with ye ole 10.5 car and have had a real ball playing with it. I'm adding a second kit to it this winter (or maybe a blown motor) so maybe some 60's.
I hurt the motor in my stratus testing stiff with wj, being in a rush, and not checking stuff between hits, so as soon as its back together ill go south and beat on it some more. Teens, or maybe an 0 anything is the goal .
I'm glad Frank digs the box car lol. That car has been nothing but fun. I treat it like a rolling dyno lol. I never keep the same motor in it for long. When the sun returns I'm adding a few more pounds of boost, and going for a 4.999999.
I really hope you get those guys lit up again to go racing, testing, whatever. You guys are going to love the new brainerd, and the new crossville
[Re: Keith Black®]
#2590229
12/11/18 03:25 AM
12/11/18 03:25 AM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
$1800ish IIRC, but don't quote me but I seem to recall close to there for the block we hurt last year.
[Re: RAMM]
#2590254
12/11/18 06:26 AM
12/11/18 06:26 AM
Posts: 4,785 Utah and Alaska
astjp2
Utah and Alaska
So it doesn't take a huge machine,Yes it does and you know it. It takes an abnormally large Z axis or a 4th axis but then you get into "Sag" it just takes a good machinist who pays attention to the setup<<Yup this is the key right here and gets the block properly fixtured and indexed. Andy you're a CNC guy as am I. I use a MAZAK Integrex 1850-V 5 axis and have built block fixturing for what can be considered one setup block machining. Still the cam bore and main bores are an issue. Everything will need a lick with a hone to become true round. Horizontal boring is not near as accurate as vertical unless using a piloted arbor. That right angle drive bore head will not be accurate . As you have pointed out a machinist never likes to break setup. Well it still takes a vigilant machinist as CNC's can do wrong. In fact I was chasing tolerances all over until I tracked it down to a worn X-axis ballscrew. It was worn .024" . $30k repair.... It takes a BIG RIGID machine with power to produce (whether it be accuracy or volume or both). J.Rob We are giving up on our mazak's at work and going with 150 horse spindle Makino's, 1200 ipm and 30K rpm. Should be coming in from Japan next month...those things are going to be loud. $34K to change a ball screw? Seems kinda high. Tim
1941 Taylorcraft 1968 Charger 1994 Wrangler 1998 Wrangler 2008 Kia Rio 2017 Jetta
[Re: Keith Black®]
#2699158
09/20/19 09:05 AM
09/20/19 09:05 AM
Posts: 4,066 Mo.
racerx
Mo.
