Re: Dying/Painting Vinyl Door Pads - Black to Tan
[Re: IMGTX]
#2565132
10/16/18 11:15 PM
10/16/18 11:15 PM
Posts: 25,050 Texas
GoodysGotaCuda
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
I went from white to black on my Challenger.
I found that if you wipe the plastic/vinyl down with a heavy dose of acetone right before you paint it the adhesion is better. It softens and opens up the plastic to be ready to bond with the paint. Just painting according to the instructions had spots peel in very little time.
Just be sure the acetone is dry enough to paint over.
Did you try their adhesion promoter?
[Re: GoodysGotaCuda]
#2565170
10/17/18 12:51 AM
10/17/18 12:51 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I've used SEM over the decades, dosen't matter, light to dark, dark to light... here's my 70 Charger interior, the seats upholtery, headliner and lower door panels are white Legendary repros, but the upper soft pads, arm rests, seat plastic hardware/trim, back window trim and other assorted panels and metal/plastic trim pcs were all black originaly, color changed with SEM, I DON"T use the adhesion promoter, I've found that causes the finish topcoat to take forever to fully dry (weeks)...
I just "wash" everything in lacquer thinner and clean white rags several times to leach out any oils/silicone/etc and make the surface "raw" for good adhesion (just allow some time between washes to let the vinyl/plastic "breath" as lacquer thinner is very aggressive), I recommend you spray from a gun for best results, and thin layers, allowing for flash time between coats, avoid one coat coverage and thick build up, for all light colors I finish with a final coat of SEM's satin or low lustre clear depending on what sheen your trying to achieve, the Low Lustre clear is basically invisible and does not alter the color/tint, and aids in cleaning without disturbing the color fastness...
I did this interior over 14 yrs ago and it still looks as fresh as day 1 with ZERO issues...
Mike
#2565189
10/17/18 01:34 AM
10/17/18 01:34 AM
Posts: 4,720 Star Idaho
67vertman
Star Idaho
Mike, as DAYCLONA stated use the SEM product! They sell a adhesion promoter and it real helps. More money then the off the self brands, but the results are well worth the efforts and extra expense.
My Monster are real!
Living within your means makes life pretty easy.
#2565429
10/17/18 04:22 PM
10/17/18 04:22 PM
Posts: 16,477 Canada
CrAzYMoPaRGuY
Canada
Adhesion promoter!!! Works awesome. I did my steering wheel, leather wrapped. Hands on it allll the time. Absolutely awesome.
CrAzYMoPaRGuY
#2565444
10/17/18 04:43 PM
10/17/18 04:43 PM
Posts: 15,831 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I changed colors and used SEM spray with great success. Lasted quite awhile until some peel started on steering wheel, which I cleaned often. I did not use adhesion promoter. Love SEM sprays, never tried their dyes.
I cleaned first with Isopropyl Alcohol.
Facts are stubborn things.
[Re: larrymopar360]
#2565480
10/17/18 05:49 PM
10/17/18 05:49 PM
CrAzYMoPaRGuY
Canada
I cleaned first with Isopropyl Alcohol. Try adhesion promoter imo.
CrAzYMoPaRGuY
[Re: DAYCLONA]
#2565604
10/17/18 09:39 PM
10/17/18 09:39 PM
Posts: 105 Ontario, Canada
D149
Ontario, Canada
Can you get SEM in colours other than the standard white, black etc.? If so, where?
Thanks Dave
1968 Valiant Signet 4dr. 273 4spd 1969 Road Runner 383 4spd 1969 Barracuda 318 auto 1970 Dart Swinger 340 4spd 1975 Cordoba 400-4bbl 1988 Caravelle 318 Auto 1999 Dakota R/T 2000 Viper GTS 2001 Ram 2500 Diesel 6spd 2018 Dodge Challenger GT (Winter beater!)
#2565610
10/17/18 09:51 PM
10/17/18 09:51 PM
Posts: 1,545 Seattle, WA
375inStroke
Special needs person
Seattle, WA
I scrubbed a set of green '68 Charger seats with trisodium phosphate, water, and a Scotchbrite. Emulsifies all oils and silicone, and most importantly, washes it all away. The acetone or lacquer thinner method just dilutes the contaminates as you wipe the surface. An autobody supply shop mixed up a quart of SEM to match the white rear seat I had, and it turned out great. No bleed through of the green, even in the pleats of the '68 seats, and it didn't peel or wear, but I sold the car in a couple years.
[Re: D149]
#2565621
10/17/18 10:05 PM
10/17/18 10:05 PM
Posts: 1,820 South Bend
John Brown
South Bend
Thanks Dave I had a paint store that sells SEM custom mix colours for me and put it in spray cans, so the answer could be yes, depending who you get yours from. They also carry about 15 premixed colours in stock in spray cans in case you don't need an exact colour match.
[Re: D149]
#2565711
10/18/18 12:00 AM
10/18/18 12:00 AM
Posts: 206 Paducah, KY USA Earth
jcruse64
Thanks Dave Call or email SEM, but yes, they can do about any color on the dyes for special order. I wanted to do dash, glove box lid, arm rests, and fiberglass door panels on my '73 truck, to the original green from that year. They said they did not have that color. One of the 4 arm rests had a section with the original color showing still. I sent it to them, and they matched it. Turned out well.
#2565921
10/18/18 01:56 PM
10/18/18 01:56 PM
Posts: 10,938 Spokane Valley, WA
Big Bad Bee
Spokane Valley, WA
Heres the solution and it works great. Buy a rattle can of the SEM white. It covers the black with ease. No need to cover it perfect. Just get it even. A fog coat and a second pass will do. Shoot the tan over the white using a detail gun in the same session. You won’t need near as much tan. It will cover evenly and really pop. I learned this trick from my paint jobber. Tried it both ways and the difference is very clear.
I’m listening.
[Re: CrAzYMoPaRGuY]
#2566647
10/19/18 09:03 PM
10/19/18 09:03 PM
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
I cleaned first with Isopropyl Alcohol. Try adhesion promoter imo. Next time I will. But I was impress without the promoter.
