Re: Bad Vibrations, Chicago Fury saga
[Re: furious70]
#2572445
11/01/18 12:15 AM
11/01/18 12:15 AM
Posts: 9,550 Sacramento CA
Morty426
Sacramento CA
I had started to wonder that. Every combo I've had in the car is supposed to be internally balanced. I've been concerned cuz this block has an 'E' stapmed on the pad and is a 71, not original to the car but was in the car when I got it with 43k in it. Engine has been rebuilt by a cheap house back in the day, had a reman tag on it. It'd be sad that if it's always had a cast crack in it and in 21 years of ownership I didn't realize it. This would be the first one I've mismatched, do they normally act up in only 1 rpm range? If your engine is marked "E"it's a 69 not a 71. 71 would be marked "G". All 69s are internally balanced.
[Re: furious70]
#2572460
11/01/18 12:40 AM
11/01/18 12:40 AM
Posts: 2,255 IL
furious70
IL
No, e for cast crank, like later 440's were stamped. It's a 71 date engine by casting date
[Re: furious70]
#2572465
11/01/18 12:51 AM
11/01/18 12:51 AM
Posts: 2,255 IL
furious70
IL
Also found a site that said take rpm/60=Hertz, don't need a sirometer. 2700rpm is about the worst spot. 45hz. Same site said for internal engine stuff take second order so 90hz. What I can't find is something that says what materials or component matches that frequency.
[Re: Morty426]
#2572479
11/01/18 01:39 AM
11/01/18 01:39 AM
Prefix "E" would be for the date (1969 I think)/ suffix "E" would denote a cast crank (originally & likely still) eng.
[Re: furious70]
#2579009
11/16/18 01:30 AM
11/16/18 01:30 AM
Posts: 877 Pittsburgh, Pa
Jeff_383
Pittsburgh, Pa
Also found a site that said take rpm/60=Hertz, don't need a sirometer. 2700rpm is about the worst spot. 45hz. Same site said for internal engine stuff take second order so 90hz. What I can't find is something that says what materials or component matches that frequency. Once you figure out your Hz, how do you figure out if it's a 1st or 2nd order harmonic? And then what is a guide for where to look at in/on the engine? I'm trying to read up, but it's almost over my head
[Re: Jeff_383]
#2579199
11/16/18 03:55 PM
11/16/18 03:55 PM
Posts: 2,255 IL
furious70
IL
Also found a site that said take rpm/60=Hertz, don't need a sirometer. 2700rpm is about the worst spot. 45hz. Same site said for internal engine stuff take second order so 90hz. What I can't find is something that says what materials or component matches that frequency. Once you figure out your Hz, how do you figure out if it's a 1st or 2nd order harmonic? And then what is a guide for where to look at in/on the engine? I'm trying to read up, but it's almost over my head I'm in that exact spot, I couldn't find any more info. the one site I found said that external stuff was 1st order, internal is 2nd order. I'm 99% sure it's not an accessory or physical interface with the chassis or something, so I went with 2nd order.
[Re: furious70]
#2579228
11/16/18 04:59 PM
11/16/18 04:59 PM
Posts: 6,560 Downtown Roebuck Ont
Twostick
Still wishing...
Still wishing...
You can eliminate all the external accessories by removing all the belts. A few minutes without the waterpump turning won't be the end of the world and it will eliminate the one big accessory, the cooling fan.
How's the crank endplay?
Kevin
