Re: N/A carb hat or offset air cleaner opinions [Re: radar] #2561423
10/09/18 02:20 PM
10/09/18 02:20 PM
Colorado front range
BcudaChris Offline
BcudaChris  Offline
AIRAID does some pretty cool stuff.
https://www.airaid.com/carburetor_hats.aspx
Carb Hats, tubing, etc. I've never used it but have noticed it being used on a bunch of gear head shows.
Re: N/A carb hat or offset air cleaner opinions [Re: BcudaChris] #2561428
10/09/18 02:38 PM
10/09/18 02:38 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Re: N/A carb hat or offset air cleaner opinions [Re: radar] #2562535
10/11/18 06:15 PM
10/11/18 06:15 PM
Philadelphia
radar Offline OP
radar  Offline OP
Philadelphia
The airraid hat is nice looking but I don’t think it’d fit. Those drop bases are smooth too but also go behind the carb too far.
This setup dropped right on and only needs a little hemmer and dolly work just behind it- there is only 1/16” now and I anticipate the motor will shake that much even with poly bushings. I’m going to try to neatly smash 3/16” or 1/4” clearance behind it. It looks like the hood will clear fine & if not the 4” tubes can get added to and routed with common turbo intake stuff. Or even a ram air or cold air setup later if I get bored of bodywork.
