Lifters
#2554632
09/25/18 06:22 PM
09/25/18 06:22 PM
Posts: 2,060 Pendleton NY
terzmo
Pendleton NY
Having issues with new lifters in a 440 block made after 68. Any suggestions on what hydraulic lifters to buy.(flat top,no rollers) Flat tappet cam. Thanks in advance
Let me put this a different way....IF a person was to build a 68 on up 440 motor and MUST have hydraulic lifters..what brand/part number is suggested.
Re: Lifters
[Re: terzmo]
#2554766
09/25/18 10:29 PM
09/25/18 10:29 PM
Posts: 2,853 Pattison Texas
CSK
Pattison Texas
making noise after sitting for a while. Did some exploring and it's lifters,not pushrods or anything else. are you running a wix oil filter? or a junk fram that has a junk anti drain back valve
Re: Lifters
[Re: terzmo]
#2554779
09/25/18 10:49 PM
09/25/18 10:49 PM
Posts: 1,134 Lost in Time
Iowan
Lost in Time
I've been told that the new hydraulic lifters from whatever company are all U.S. made but the guts are made in china. Bleed down is a problem with most of the lifters out there. Crane came has been a good supplyer probably because of old stock.
Have a great day Iowan
"obsolete is neat"
Re: Lifters
[Re: terzmo]
#2555016
09/26/18 01:29 PM
09/26/18 01:29 PM
Posts: 14,493 So. Burlington, Vt.
These days, buying new BB Mopar oe replacement style lifters is a crap shoot for where they fall within the acceptable “bleed rate” range.
For American made parts, I believe you’re going to be limited to HyLift Johnson or Stanadyne....... possibly still something made by Eaton.
Re: Lifters
[Re: terzmo]
#2555091
09/26/18 04:24 PM
09/26/18 04:24 PM
Posts: 17,841 S.E. Michigan
ZIPPY
S.E. Michigan
Mopar Performance lifters were USA Johnson Hylift, back in 2013. Long story. Hope they haven't changed.
Rich H.
Esse Quam Videri
Re: Lifters
[Re: terzmo]
#2555584
09/27/18 03:39 PM
09/27/18 03:39 PM
I looked at the Johnson site. They show three versions of hyd flat lifters for Mopar...... reduced travel, short travel, fast bleed. $400-450 msrp
I was told Eaton was back in the flat tappet business again. I just looked it up....... technically they are, but it’s not like they started making them again.
They bought the Mexican company Morestana in 2005.
I see some places selling a few parts from Stanadyne, but I think it’s just leftover stock.
So, for stock replacement type BB Mopar lifters made in the USA, it’s probably down to just HyLift Johnson.
